Farmall Tractors Discussion Board
Re: Re: Wide front on an A
Posted by Steve T on October 03, 1999 at 07:35:20 from (208.150.193.82):
In Reply to: Re: Wide front on an A posted by Otis on October 02, 1999 at 18:31:37:
Thanks for the comment.I found this A purely by accident, and couldnt pass up a $75.oo dollor buy. When I found it, the grill, radiator, and seat were missing. after doing a little digging, we found 2 radiators and a power unit. I discovered that the grill off of the power unit will fit the tractor. I bought the tractor, power unit, and a 2 cylinder Wisconson engine for only $100.00 bucks, and took it all home. After blasting all the years of grease of it, I discovered that the front end had been damaged, looked like they hit something hard, and then welded it all back together. Looks like Ill have to find another front end. The engine had spark and compression so I knew it would run, and all it took was a little fuel, and off it ran. I put the radiator on it and filled it up with water, only to find that all the water went into the crankcase, bummer. I havent had the time to tear down the engine yet to see where the leak is, and Im afraid to do so. It wasnt the bargin I thought it was, but oh well, I got another project.BTW, any clue's on where the water is leaking? Im hopeing just the liner seals.
Steve T
Post a Followup
: Re: Re: Re: Wide front on an A
