Re: 53 SMD
Posted by Roger WI on November 17, 2003 at 19:56:59 from (69.58.142.154):
In Reply to: 53 SMD posted by 49 Cubber! on November 16, 2003 at 17:56:04:
As Karl did, I completely rebuilt a 1949 MD. I have about the same amount into it as Karl had, about $8000. My block and head were OK so it was a matter of rebuild kit and injector pump/injector rebuild. The engine is where I spent the most money. When I was done, it is my favorite tractor next to my Super H, A, B, and Super C. Like Karl said, there are a lot of questions about why does this diesel tractor have spark plugs. Roger
Post A Followup
: Re: Re: 53 SMD
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
