Re: Problems with F12 broken parts
Posted by Luke on November 18, 2003 at 13:57:09 from (63.153.0.77):
In Reply to: Problems with F12 broken parts posted by old on November 18, 2003 at 06:16:08:
i too have an F12....with the repaired block.....water jacket on the left side.as usual....i used good old JB WELD....works fine.
the manifold is available from rice equipment...
brand new....looks great..not rusted out like the junkyard ones. as far as getting her unstuck:try a mixture of oil and brake fluid in the cylinders...does the trick. parts are available like they say...and pretty cheap.
good luck.
Luke
Post A Followup
: Re: Re: Problems with F12 broken parts
