Re: W-9 Magneto rotor drive timing
Posted by Bob on November 18, 2003 at 21:14:41 from (66.231.124.49):
In Reply to: W-9 Magneto rotor drive timing posted by Rod on November 18, 2003 at 19:24:58:
I can't give you the answer, as I am away from my shop manuals. My best guess is that the W-6 mag turns the same direction as the M or H, but you can easily check it out for yourself.
H and M magnetos turn clockwise when you face the impulse drive end, and you use the tooth labelled
"R", is in RIGHT HAND ROTATION.
Verify which way your mag turns, and go from there.
Post A Followup
: Re: Re: W-9 Magneto rotor drive timing
