Posted by Janicholson on March 10, 2009 at 08:26:39 from (64.83.225.108):
In Reply to: farmall super A posted by Darrelll Hill on March 09, 2009 at 20:16:25:
As noted below, there are two ways it can get there. One is extreme flooding, the other is excess choke, or a cylinder not firing allowing raw fuel to bypass rings. Do the following. Always shut off the fuel at the tank valve when stopping the tractor for even a few minutes (just get into doing it) If it runs rough, do a tuneup including a compression check. Change the oil and monitor the level. It could also be hydraulic oil. (I heard you say gas, but Hydraulic oil can cause overfilling in the crankcase from a bad seal in the pump. JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
