still HAVING BIG TROUBLE WITH MY IH 444 TRACTOR WA
Posted by Rick on November 20, 2003 at 04:48:45 from (64.44.153.14):
I know this is long but bear with me. I'M HAVING BIG TROUBLE WITH MY IH 444 TRACTOR WANTING TO DIE ON ME AFTER IT HEATS UP AND GETS UNDER A LOAD. IT WAS RUNNING JUST FINE AND THEN ONE DAY.......PLAAA! I'VE REPLACED THE POINTS AND CONDENSER AND ROTOR CAP, CLEANED OUT THE CARB. NOTHING, ADDED AN INLINE FUEL FILTER, REPLACED THE COIL, THEN REGAPPED THE POINTS. BUT IT JUST KEEPS GETTING WORSE IT ALSO WANTS TO BACK FIRE WHEN I TRY TO RESTART IT BUT IT WILL NOT RESTART UNTIL IT COOLS OFF COMPLETELY. ANY SUGGESTIONS? ONE STRANGE THING IS THAT I CAN HOLD ONTO THE COIL TO DISTRIBUTOR CAP WIRE WHILE IT IS RUNNING. EVERYONE SEEMS TO THINK I SHOULDN'T BE ABLE TO DO THAT WITHOUT GETTING ZAPPED. I'VE LOOKED AT ALL THE WIRES AND CAN'T FIND ANY SHORTS OR BREAKS. I'VE ALSO RUN A WIRE STRAIGHT FROM THE BATTERY TO THE POSITIVE SIDE OF THE COIL THAT DIDN'T HELP OR CHANGE ANYTHING EITHER. I'VE CHECKED FOR MOISTURE AND CRACKS IN THE CAP. IT WILL USUALLY RUN A GOOD STEADY HOUR BEFORE IT WANTS TO DIE. I'VE BEEN MESSING WITH THIS THING FOR WEEKS AND CAN'T TROUBLE SHOOT IT. I'M PRETTY SURE THAT I HAVE GOOD FUEL PRESSURE I'VE CHECKED THAT THE NEEDLE VALVE OPENS AND CLOSES AT INSTALLED POSITION, THE NEW FUEL FILTER IS CLEAR SO I CAN SEE THAT IT MADE IT TO WITHIN 3" OF THE CARB. THE TRACTOR HAS AN ELECTRIC FUEL PUMP AND IT'S STILL PUMPING GOOD. Follow up. 11/20/03 I have changed the coil, the points, condenser, and rotor button, I’ve tried it without the gas cap, and I’ve made sure it still has gas in the carb. after it stops running, by taking the drain plug out of the bowl. I made a new wire from the coil to the points. I’ve dried inside the cap and sprayed it with WD40, I looked at the insulator between the points and distributor itself to make sure it's not cracked. I replaced the coil wire and checked all the plug wires. The dist. cap looks fine. Twice now I’ve taken the dist. cap off and looked things over touched stuff inside and put the cap back on and it fires right up, but then it goes back to doing the same thing just when I think I’ve fixed it. When it does start it runs fine, making me think it's not gas or carb. problems, but as soon as it gets hot and I bog it down it wants to die and then will not restart, now I’m even having trouble starting it cold. The timing has never been touched since it was running fine before all this started. I’m afraid to mess with it. The exhaust is out the top. I’m lost and about to give up and hire it out to get fixed but I really hate to because I think it's got to be something simple or crazy that I could fix myself. The strange thing I asked about before, touching the coil wire while it's running. Should that be possible without getting shocked??? Thanks for all the suggestions, but so far I can't make any of them the fix it. Still looking for that magical idea.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
