Re: Re: Re: Not sure if my tractor is a 400 or 450
Posted by Hugh MacKay on November 20, 2003 at 12:53:02 from (64.228.11.163):
In Reply to: Re: Re: Not sure if my tractor is a 400 or 450 posted by Guy Fay on November 19, 2003 at 14:33:49:
Guy: I am not going to argue with you, however there is not the slightest sign on a letter in the casting codes of my 130 or 140. I waited until today in good daylight and used a knife and wire brush.
My Super A is serial number 336977 making it a 1953 and the engine block, torque tube, transmission case and touch control are all clearly marked X.
My Farmall 130 is serial number 9313 J making it a 1958 There is not the slightest resemblance of a C or a D on any of those codes.
My Farmall 140 is serial number 22157 J making it a 1963. Again there is not a sign of any letters. There are quite clearly numbers in these casting codes, and everyone of those numbers are legible. There was a discussion on here some time ago, and I do forget the title, but some of the participants suggested letters were not used beyond the 100, 200, 300 and 400. My two tractors not having letters I accepted this as being so.
I am 62 years of age still have 20-20 vission but do use reading glasses, for close up. I invite you to send anyone here to check this out. There are a couple of regular YT posters within 30 miles.
Post A Followup
: Re: Re: Re: Re: Not sure if my tractor is a 400 or 450
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
