Re: Which is best when changing to 12v?
Posted by jdemaris on November 20, 2003 at 17:24:31 from (209.23.29.130):
In Reply to: Which is best when changing to 12v? posted by Jim in NC on November 20, 2003 at 16:18:44:
I'm not sure what you mean by "performance." A gas engine is good condition will run the same with 6 volt coil getting 12 volts or a 12 volt coil getting only six volts. Ignition point life will be affected though. The ratio determines "potential" current, i.e. an ignition system will only produce the amount of current necessary to jump the gap in the spark plug. So . . . even though one setup is capable of higher output than the other, you won't notice it under normal circumstances. Variations, e.g. increased gap, or high resistance plugs wires can demand more voltage, so it's possible have a condition where one system might outperform the other in unusual situations. John Deere had the bright idea to use 6 volt coils with 12 volt systems along with a ballast resistor. The system worked okay but the ignition points didn't last very long. Anyway, in my opinion and experience, a good old fashioned 12 volt coil hooked to a ballast resistor works fine. Along with it there should be a resistor bypass hooked up for when the starter is cranking the engine (to aid in cold weather starting). There are many ways to do this. Some starters already have a bypass terminal on the solenoid. There are also ignition switches available with a bypass such as John Deere used. Also, which I find to be very reliable and adaptable to virtually any tractor, is get a starter relay like Ford used on their cars and trucks (and tractors) up the late 70s. The relay has a resistor bypass built into it and costs around $10.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
