Re: Farmall H drawbar question
Posted by CNKS on November 21, 2003 at 18:41:11 from (207.178.96.212):
In Reply to: Farmall H drawbar question posted by Pat Connors on November 21, 2003 at 11:34:13:
The two bolts that pivot in the part that clamps to the rear of the axle housing were the same for all rear mounted implements. The part that clamps to the front of the axle could be for about anything, and there were a lot of variations. Also, some implements used inner brackets, some outer. The drawbar used the inner brackets. Your setup was not for a quickhitch.
Post A Followup
: Re: Re: Farmall H drawbar question
