Farmall Tractors Discussion Board
Re: Cold Blooded
Posted by Bob M on October 04, 1999 at 06:16:24 from (192.232.120.194):
In Reply to: Cold Blooded posted by Justin on October 03, 1999 at 21:44:58:
M's have been long noted for easy starting in cold weather. Assuming yours is cranking over OK, check the following:
1 - Choke closing fully, and the choke plate is properly positioned on the shaft (no gaps whatsoever between the plate and the air passage when closed)
2 - Clean plugs, properly gapped. Recommend Champion D-21 or equiv "hot" plug for cold weather operation.
3 - Points in good shape and properly gapped. Distributor clean and dry inside.
4 - Make sure you have fresh fuel. Gas that's been sitting in the tank all summer will have evaporated it's light fractions - this results in hard starting.
Good luck!
Post a Followup
: Re: Re: Cold Blooded
