Re: Water from the Exhaust
Posted by Brian in MO on November 22, 2003 at 19:15:56 from (216.73.199.142):
In Reply to: Water from the Exhaust posted by Del on November 22, 2003 at 15:32:53:
First question is does water (anti-freeze) disappear from your radiator? If it does you have a problem, if not then it very well could just be condensation in the exhaust. My 300 will do this if it has been run and shut off alot without being really warmed up and ran hard especially in cooler weather. Brian
Post A Followup
: Re: Re: Water from the Exhaust
