Farmall Tractors Discussion Board
Re: Farmall 140 Front blade attachment pin
Posted by Curt Cooke on October 04, 1999 at 06:50:46 from (207.75.224.250):
In Reply to: Farmall 140 Front blade attachment pin posted by Brian on October 04, 1999 at 06:29:52:
Brian, be aware that the "pin" does not pass through those ears unless your blade is different than any one I've ever seen. It passes through the square in the front axle housing. It is "bushed" so to speak by two square "nuts" that are inside the axle housing which are held in their positions by a 1" pipe spacer. The rod is nothing special, just a piece of 5/8" or 3/4" steel rod. If questions persist, let me know?
Post a Followup
: Re: Re: Farmall 140 Front blade attachment pin
