Re: Re: Setting the Points Engine Timing
Posted by Allan on November 23, 2003 at 14:19:16 from (148.63.132.164):
In Reply to: Re: Setting the Points Engine Timing posted by Nebraska Cowman on November 23, 2003 at 13:28:48:
Hi again, Dwell is the period of time, measured in degrees of rotation of that distributor shaft, in which the points are closed, thus allowing the field windings in the coil to charge to a sufficient amount to give a good spark at the next collapse cycle. In other words, it is a "fine-tuning" of the points and is measured with a meter called a dwell meter. The specs are usually given in the tune-up charts and are usually given in a range such as: 27 to 32 degrees, for example. Remember the little metal “window” on the GM distributor caps back in the days of their engines using points? This was to allow the points to be set with the engine running using a dwell meter and an allen-wrench. Downside: At the time that our old tractors were born, analogue and digital dwell meters were mostly unheard of; and most of the specs were just given in “thousandths of an inch” gap measurements. However, given a good distributor with a good set of bushings, these “gap” measurements will correlate very close with proper dwell angles. The point I was trying to make was that the final point setting does indeed affect engine timing; and more aggressively than what a guy would guess. This is why it is important to set the points first prior to adjusting the engine timing, because doing it the other way around, allows the process of setting the points to again change that engine timing. Hope I’m making sense here. Later, Allan
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
