Re: Removing front pulley, Farmall A
Posted by K-Mo on November 23, 2003 at 15:16:12 from (65.169.189.2):
In Reply to: Removing front pulley, Farmall A posted by Mark on November 23, 2003 at 14:44:46:
Mark,
The end of the crankshaft should have a hole with threads. I screw a bolt into the hole to protect the threads and use a "gear puller" and a "bearing separator". If you don't have a bearing separator, Harbor Freight has them. Use the bearing separator to grab the pulley hub and pull on it instead of directly on the pulley flange. Often the pulley will break before you get it off if you pull on the pulley flange. I usually apply a little bit of heat, not much just a little.
After you get it off you may find that the pulley has a groove worn into it by the oil seal. Repair sleeves are available. I beleive NAPA may have them. The other solution is a new pulley.
To install the pulley, screw a threaded shaft into the hole in the end of the crankshaft and pull it on with a nut. Of course clean and lubricate the the crankshaft and pulley. Again I warm the pulley just a little.
Just take your time and go slow. This is not a place for big hammers.
Good Luck,
K-Mo
Post A Followup
: Re: Re: Removing front pulley, Farmall A
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
