Re: Removing front pulley, Farmall A
Posted by Steve on November 23, 2003 at 16:48:45 from (209.143.27.190):
In Reply to: Removing front pulley, Farmall A posted by Mark on November 23, 2003 at 14:44:46:
Had the same problem on my Super A. After I broke the pulley off the hub, I found someone had welded it sometime before. I tried a huge puller with heat and still wound up cutting the hub off the shaft. Mine didn't even have the bolt in the end of the shaft. Just the interference fit held it in place. At least you can use the threaded hole to draw the new one back on. Yes it's a lot of grief to go through just to change that seal. NOT one of IH's better engineered areas. Good luck !
Post A Followup
: Re: Re: Removing front pulley, Farmall A
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
