Farmall Tractors Discussion Board
Compression readings for a cub
Posted by Steve on October 04, 1999 at 07:26:32 from (206.5.110.15):
Can anyone tell me what a "good" compression reading would be for a cub? Also what is the maximum difference between cylinders?
Also, if the engine needs a re-build, since the valves are not in the head and have no inserts how do you re-build the valve train?
Also, since there are no bearings for the camshaft, is there likely to be a problem with the camshaft or is this pretty bulletproof?
Thanks for any help...Steve
Post a Followup
: Re: Compression readings for a cub
