Re: Where would you look first for spark problem?
Posted by Michael Soldan on November 24, 2003 at 15:10:30 from (216.46.130.25):
In Reply to: Where would you look first for spark problem? posted by Paul Shuler on November 24, 2003 at 09:53:21:
Paul, from time to time my old M won't start because of weak spark, I remove the mag, take the plate off the end and using fine emery cloth I give the points a good cleaning and then reassemble. The M usually starts on the second crank when I do this...mags last a long time and although you could have a bad mag it is rare...more likely the points that are the problem..Old and Bob M. concur.......Mike in Exeter Ontario
Post A Followup
: Re: Re: Where would you look first for spark problem?
