Re: Re: Re: H Transmission Lift-All drive dog a
Posted by Wayne Swenson on November 25, 2003 at 21:26:26 from (66.228.233.238):
In Reply to: Re: Re: H Transmission Lift-All drive dog and s posted by John on November 25, 2003 at 15:47:00:
When the drive or driven nuts with the slots in them are installed, they automatically tighten up to a shoulder on the threaded shaft. They should not be loose, in fact you should tighten them a little when installing seals because that helps prevent oil leakage past the threads.
Try loosening the 4 mounting cap screws on the bottom of the Lift-All pump and pry the pump towards the rear and then re-tighten the cap screws; you may be able to move the pump a fraction closer.
I doubt the connecting shaft & retaining collars will ever wear out in your lifetime so do not concern yourself with a little slack.
Post A Followup
: Re: Re: Re: Re: H Transmission Lift-All drive dog a
