Re: FARMALL H RUN'S ROUGH
Posted by aaron on November 26, 2003 at 11:51:27 from (130.20.144.60):
In Reply to: FARMALL H RUN'S ROUGH posted by JIM GILLER on November 25, 2003 at 19:38:11:
If you are having to tease the choke then it is a fuel delivery problem. Probably icing like the others have mentioned. Or it could be a clogged filter where the fuel line screws into the carburetor. There is a small tube shaped filter of wire mesh just inside the carburetor housing where the fuel line attaches. Use a 5/8 wrench and remove to inspect and clean.
Post A Followup
: Re: Re: FARMALL H RUN'S ROUGH
