Re: 48 Cub with a charging problem
Posted by Rudi on November 27, 2003 at 16:56:19 from (24.230.211.52):
In Reply to: 48 Cub with a charging problem posted by Dave on November 27, 2003 at 09:22:23:
third party image
Dave:
If you check on the link below, it will take you to the Cub server. On the server is a couple of links to some very informative information.
Read the Best of H.L. Chauvin - his advice is invaluable.
Check out the GSS-1012 Electrical Service Manual under Blue Ribbon Service Manuals. The whole diagnostic procedure is spelled out.
Check the wiring diagrams that you will find on the Cub FAQ's #2 link, they will help you chase down the wiring.
Also, the Owner's Manual will tell you clearly how to polarize the generator. Oh, on a 48 you most likely have a cut-out and not a regulator. Make sure that your are still positive ground.
Post A Followup
: Re: Re: 48 Cub with a charging problem
