Re: Can I use a magneto with a 12v system ?
Posted by Doug in OR on November 28, 2003 at 14:09:54 from (12.225.61.140):
In Reply to: Can I use a magneto with a 12v system ? posted by onlytony on November 28, 2003 at 08:33:07:
A magneto needs no battery at all. It produces it's own spark. When you convert to 12 volts (which would be mostly for starting purposes anyway), you generally use negative ground. The main reason for this is that an alternator is generally used, which almost always wants a negative ground.
The only thing you need to allow for when using a magneto and an alternator is... the alternator usually uses a connection to the ignition switch for the exciter connection. You have no ignition switch on a magneto, so you would need to install an additional switch.
Post A Followup
: Re: Re: Can I use a magneto with a 12v system ?
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
