Re: F-20 Trans.-Rearend
Posted by Ron on November 28, 2003 at 17:10:42 from (152.163.252.227):
In Reply to: F-20 Trans.-Rearend posted by John in Ne. on November 28, 2003 at 11:15:40:
Well, if you are self motivated, it's no problem. You need to first remove the brake drums, the bearings/housings, and then pull out the cross shafts. Next you need to take off the rear sheet metal dome cover. Then you need to remove all the bolts/nuts and separate the housing and the rear end. Oh, and in some cases, you need to take off the differential pig unit to get access to the bolts and nuts. I should take a good sunday to break it down. Good luck and HAve fun!!!!!! Ron in Michigan
Post A Followup
: Re: Re: F-20 Trans.-Rearend
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
