Re: Re: Re: Going to attempt clutch job on 400
Posted by Yoda the tractor spliter on November 28, 2003 at 17:33:59 from (64.136.26.225):
In Reply to: Re: Re: Going to attempt clutch job on 400 posted by Kelly C on November 28, 2003 at 16:59:11:
The easiest way is to get some high grade all-thread grade 8 is best. I think the tread size of an M is 3/4". The last one I did was an H and I used 5/8" all-thread. That job took 1 hour 30 min to include detaching the steering and what not. I need to take pictures of such projects as you have on your web sight. Im splitting a Super M next week. Should be loads of fun. Oh one more thing!! When you go to push it back together you need to have the tranny in Neutral and use your engine crank to line up the clutch shaft splines to the clutch plate. This is the toughest part of the task. Take loads of pictures for the websight. Good luck
Post A Followup
: Re: Re: Re: Re: Going to attempt clutch job on 400
