Re: Electric Start for F12/F14
Posted by Zak on November 29, 2003 at 15:34:44 from (64.12.97.12):
In Reply to: Electric Start for F12/F14 posted by Fawteen on November 29, 2003 at 13:09:12:
I've seen a conversion done on an F-14 in a local junkyard where someone welded the starter mount to the right side frame rail. They then installed a ring gear into the clutch to transmission linkages. I can take pictures for you next time I'm there if you want an email them to you. Probably be going by this coming Monday. This method doesn't require modifying the bellhousing but you do have to weld a bracket onto the rail. Zak
Post A Followup
: Re: Re: Electric Start for F12/F14
