Re: F-20 Trans.-Rearend
Posted by Dave@NY on November 30, 2003 at 05:22:52 from (216.42.140.99):
In Reply to: F-20 Trans.-Rearend posted by John in Ne. on November 28, 2003 at 11:15:40:
Have just done this exact thing to my Regular.I removed the final housings w/bull gears,counter shafts,differental-ring gear assemblys as I am redoing the gaskets and felt seals througout.Used a cherry picker to support the housing while removing from the transmission.Not a really bad job just greasy,takes a few hours.The bearing caps for the diff. assy. will push off by using a longer bolt in the hole for the retaining clips of the bearing adjusters.This is the 5/8" size head bolt in the center of the cap.Hope this makes sense.
Post A Followup
: Re: Re: F-20 Trans.-Rearend
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
