Re: Cause of Tractor Fire?
Posted by JB on November 30, 2003 at 12:48:03 from (67.69.53.49):
In Reply to: Cause of Tractor Fire? posted by Gramps544 on November 30, 2003 at 11:42:22:
Gramps, had a B414D catch fire. Just like someone else said don't put tractors in the shed hot. In our case the voltage regulator shorted out wiring to generator, melted a hole in the plastic injector return line and Diesel fuel began to burn as it dripped from hole in return line. Luckily we saw smoke from shed and were able to extinquish fire before much damage.
JB
Post A Followup
: Re: Re: Cause of Tractor Fire?
