Re: Farmall 100 charging post #2
Posted by Janicholson on March 31, 2009 at 07:07:15 from (199.17.6.128):
In Reply to: Re: Farmall 100 charging post #2 posted by chad from michigan on March 31, 2009 at 06:40:16:
With the battery disconnected, pull the top off of the VR. There will be two coil/relay looking units in there. Reconnect the battery (the cap can violently short out the system as it is removed!!)
One will be the cutout relay. It will have a heavy winding around it (probably) and heavy contacts.
The other will have smaller contacts. With it running at 1/2 throttle or more, use a small twig, or plastic knife/spoon/fork handle, to push the small set of contacts together more (apply pressure lightly in the close contact direction) The generator should begin to increase out put. If it does, then use a volt meter to assess the battery voltage (across the battery termonals) and adjust the spring, tab, or screw to cause more pressure on the contacts.
as you do this watch to be sure you do not short anything to ground (smoke). The voltage should be set to 7.2 to 7.3 volts.
Shut it off, disconnect the battery, and put the cover back on the VR. Restart, and check the voltage. The voltage may have changed due to the cover's effect on the magnetism in the vr. IF TOO LOW OR TOO HIGH, ADJUST AS ABOVE TILL GOOD. This can take two or three removals of the cover. If it has no effect when pushing on the contacts, a new (possibly NAPA) VR is needed. JimN
