Re: F20N Update/Questions
Posted by Mike Androvich on November 30, 2003 at 17:42:25 from (24.50.141.187):
In Reply to: F20N Update/Questions posted by Tony on November 29, 2003 at 08:45:35:
The small set screw holds in place the crankshaft starting pin. It is a small miracle that you were able to get this screw out. Usually they have to be drilled out. The crankshaft starting pin is not a loose fit in the hole in the crank. You will have to take a drift pin, or a long punch and drive it out. Be careful not to hit the pulley with the hammer, you will take out a chunk of it real quick. The nut has a flat sheet metal keper on it to keep it from coming loose. Flatten the part that holds the nut in place and remove the nut with a socket if you can. Worst case is to loosen it with a chisel and hammer. After the nut is loose the pulley will normally pull off with a little persuasion. Sometimes you have to get a pulley puller to get it off. In any case, this has to come off in order to get off the timning cover. Also the front seal of the engine is right at this spot too. I have done this job many times, and it is usually not too hard. Good luck!
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
