Re: Re: Cause of Tractor Fire?
Posted by ken on November 30, 2003 at 17:57:10 from (216.16.92.228):
In Reply to: Re: Cause of Tractor Fire? posted by Peabody on November 30, 2003 at 16:49:07:
hugh brings up a good point don't fuel up hot i usually let it set 20 minutes to half hour to refuel if it's hot and then let set another 10-15 minutes before restarting same for shutting it off i usually park about 20 feet in front of the shed and turn the gas off and let run for about 30 seconds then shut down and let it cool down because i have to take the muffler off because it stands about 2 inchs taller than my garage door is high and i pull it off with my hands so if it's too hot to handle it sets til it is.then i start it and back in the shed and let run til it dies unhook the battery and put the muffler back on.
Post A Followup
: Re: Re: Re: Cause of Tractor Fire?
