Re: Farmall Super A Transmission gears
Posted by Roger WI on November 30, 2003 at 19:53:19 from (69.58.143.75):
In Reply to: Farmall Super A Transmission gears posted by Blaine on November 30, 2003 at 19:37:26:
Blaine, That gear is the same on the A and B. The C is a different transmission. I think the 100 transmission is also the same as the A and B. I just changed that gear on my B when I rebuilt it. I ended up completely disassembling the transmission as it is at the end of the bottom shaft and you need to take it all the way out to get that gear off. That gear is only needed if you do a lot of PTO work with the tractor standing as when the tractor is in any gear the gears get lubricated. Roger
Post A Followup
: Re: Re: Farmall Super A Transmission gears
