Re: Hydrolic Belly pump on H, what can it do ?
Posted by Haas on December 01, 2003 at 13:11:41 from (12.65.6.79):
In Reply to: Hydrolic Belly pump on H, what can it do ? posted by Jody on December 01, 2003 at 11:15:07:
The belly pump only puts out about 800 psi of pressure which is lower than modern hydraulics. You can compensate for the lower pressure with a larger diameter cylinder. Also the system is only one way, which means it lifts, but down is gravity. You can make it two way by adding a two way open center control valve. You pipe from one of the pressure ports on the belly pump to the new valve and then pipe the return from the new valve to either the fill port for the belly pump reservoir or to the drain of the belly pump. Pipe from the new valve to the two way cylinder. When you want to use the two way system, lock the lift all operating rod in the lift position and then fluid circulates through the control valve and back to the reservoir, or to the cylinder when you operate the control valve. This does no harm to the belly pump as it circulates internally all the time anyway and you are just changing the cirulation to be external. The pump should have plenty of pressure and flow to operate a snow blade. Of course you realize the belly pump is not live and only operates when the clutch is engaged.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
