Re: Farmall 100 front end loader
Posted by Hugh MacKay on December 02, 2003 at 16:32:54 from (209.226.247.144):
In Reply to: Farmall 100 front end loader posted by jeff 76 on December 01, 2003 at 06:24:31:
Jeff: Over the years there were two different loaders for the offset tractors. The first was a pipe frame loader, a two arm loader, sinilar in design to the 33 and 34 loaders used on larger tractors in the 50s. I don't remember the model number. It was a trip bucket.
Later on in the days of the 140 the model 1000, a one arm loader came out complete with down presure and hydraulic bucket. Both these loaders are very scarce as probably less than 2% of these tractors ever had loaders. There is a good reason for this. The factory loaders will only lift about 500 lbs. Anymore than that and your front end would be history anyhow.
Post A Followup
: Re: Re: Farmall 100 front end loader
