Re: Re: Re: Re: light problems for 12 volt convers
Posted by Doug in OR on December 03, 2003 at 19:12:31 from (12.225.61.140):
In Reply to: Re: Re: Re: light problems for 12 volt conversion posted by Bob M on December 03, 2003 at 13:46:45:
The band should be on the side facing the alternator. Go to Radio Shack and ask for a 1N4001, 1N4002, 1N4003 (the last digit is the voltage rating, in 100 volt multiples) diode. These are common diodes. As Bob said, you can wire direct, tho I prefer to put a resistor (27 to 47 ohms, 2 watt - ohm value is not critical) resistor in series with the diode. This is purely as protection. It acts as a current limiter and could save your diode if you develop a wiring short.
Post A Followup
: Re: Re: Re: Re: Re: light problems for 12 volt convers
