Re: Type of Calcium chloride used in tire question
Posted by Dieselrider on December 04, 2003 at 04:11:53 from (66.82.168.1):
In Reply to: Type of Calcium chloride used in tire question posted by Ray in Pa. on December 03, 2003 at 21:15:22:
Ray,
You want the flake for mixing your own. It mixes real easy, you ca use a drill with a 1/2" rod to mix, like one of those paint mixers. I don't know about the other type being different just a little harder to mix. I wouldn't think lime would make less toxic as lime isn't very good on metal either.
What part of Pa are in? I'm in southern Clearfield County.
Post A Followup
: Re: Re: Type of Calcium chloride used in tire question
