Re: Farmall steering wheel removal
Posted by Gary V on December 04, 2003 at 19:18:22 from (4.72.105.138):
In Reply to: Farmall steering wheel removal posted by Jason on December 04, 2003 at 09:16:21:
I just removed mine last week and had the same problem as you.Try heating it up with mapp gas tourch all around. This gas will get it very hot . Be careful not to get it to hot.Let cool for about 5 min. and spray penetrating oil on it.repete after cooling.Let cool again an use impact wrench if you have one.To get the wheel off the shaft do the same. You will have to use a 4inch puller. tighten down on it and tap on wheel hub.it should start to to break loose with a little help of a hammer. Tighten down again an tap on hub. Good Luck
Post A Followup
: Re: Re: Farmall steering wheel removal
