Farmall Tractors Discussion Board
Re: Re: Re: Re: Getting more power from a distilate Super M
Posted by mark on October 05, 1999 at 15:23:13 from (12.13.129.121):
In Reply to: Re: Re: Re: Getting more power from a distilate Super M posted by jakee on September 30, 1999 at 21:10:16:
i have two m's that i pull. i use 8060 heads
they are closed chambered and work well but for serious power porting and polishing is the way to go. what do you think?
Post a Followup
: Re: Re: Re: Re: Re: Getting more power from a distilate Super M
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
