Re: Re: Re: Re: HELP!! Rear main seal replace on 4
Posted by justin on December 06, 2003 at 10:58:42 from (216.188.198.180):
In Reply to: Re: Re: Re: HELP!! Rear main seal replace on 400 posted by Kelly C on December 06, 2003 at 09:36:04:
do you mean the U shaped gasket that has two 1/2 holes cut in the outside of the two short sides? this is the gasket that has to be replaced by removing the oil pan. Kinda confusing to explain, but if you look in a parts book I think you will understand how it goes. The same basic rear seal design was used on the H thru the 450.
Post A Followup
: Re: Re: Re: Re: Re: HELP!! Rear main seal replace on 4
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
