Re: H Engine Sludge Cleaning
Posted by 42FarmallH on December 07, 2003 at 10:40:19 from (12.23.184.183):
In Reply to: H Engine Sludge Cleaning posted by Gary on December 07, 2003 at 10:13:36:
Since you have oil pan, valve cover, and side cover off: Use Kerosene or solvent (better idea is solvent) and a scraper/paint brush/tooth brush to clean away as much as you can.
As far as running it with something to clean it out, this is what I would do: fill with oil, add 1 quart kerosene, new oil filter. Run for 5 to 10 minutes and drain. Re-fill with fresh oil and new filter again, run 30 minutes or more - drain again to remove any left over kerosene or junk. Re-fill with fresh oil.
If you don't think you can get all the sludge out, simply use 30 weight NON-detergent oil. A detergent oil will break the sludge loose, possibly clogging oil passages.
This is just an opinion on what I would do.
Post A Followup
: Re: Re: H Engine Sludge Cleaning
