Re: Rear main seal on IH 1066
Posted by pcy on December 07, 2003 at 13:44:58 from (199.35.246.160):
In Reply to: Rear main seal on IH 1066 posted by Vern on December 06, 2003 at 19:27:00:
i took a flat pieca steel 1/2 inch thick, drilled 4 holes to match the flywheel bolts, bolt it on press the seal into place with the fly wheel bolts, take it back off , i bolt some allen head bolts 1 inch long i got at at a milletary surpluse store, put the plastic ring that comes with the seal , put the short bolts in tighten them up, seal is pressed to correct depth, it works great, ive put dozen;s of rear seals in andhad no problems , less than 20 bucks invested
Post A Followup
: Re: Re: Rear main seal on IH 1066
