Re: Shifting help
Posted by Hugh MacKay on December 07, 2003 at 15:38:04 from (209.226.247.132):
In Reply to: Shifting help posted by Mitchell Pool on December 07, 2003 at 14:02:09:
Mitchell: There is a process called double clutching, hard to do on a tractor as your rolling speed is not fast enough. This was used in big trucks for years. It worked reasonably well on Farmalls before the days of TA. It is best to practice this on slight down grades. A tach is also ideal. Sequence of this is bring tractor to full throttle in 4th, depress clutch and remove shift from 4th to neutral, at same time you throttle back tractor and release clutch when tractor is in neutral. This slows front shafts and clutch to match 5th gear. You then immediately depress clutch again and slip tractor into 5th. As young lads my brothers and I mastered this on letter series Farmalls. Trucks of that era had to be shifted this way or use no clutch at all just adjust your throttle to match gear you are going to. You would find this much easier if you had an old truck to practice on. Because the tractor rolling speed is so slow this is quite difficult, but not impossible. Something you may try to give you a feel for this is get your M on reasonably level ground. Practice going from 2nd to 3rd and back again without using clutch. Just let off throttle enough to allow shift lever to neutral, the trick from here is to adjust throttle so engine speed matches transmission speed and be fast as tractor loosing momentaum is also a factor.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
