Re: Re: Re: Re: Help! Broken Shear Pin stuck
Posted by Ed Hotaling on December 08, 2003 at 11:46:28 from (199.232.76.211):
In Reply to: Re: Re: Re: Help! Broken Shear Pin stuck posted by Van on December 08, 2003 at 07:00:17:
I've done this for years. The broken stub will
usually come right out with a couple of light
taps.
Another tip would be to start the engine and turn
the auger shaft until the bolt hole is at an angle
that is easy to work on. Use low throttle and
"bump" the auger clutch until it's where you want
it.
Post A Followup
: Re: Re: Re: Re: Re: Help! Broken Shear Pin stuck
