Re: Continuing missing F-20 engine saga
Posted by Nebraska Cowman on December 08, 2003 at 15:57:13 from (65.172.142.97):
In Reply to: Continuing missing F-20 engine saga posted by Pete L on December 08, 2003 at 10:22:10:
erratic firing under no-load is real common on F20s. I believe it is caused by the spark jumping on the rotor distibutor block. I take them out and sand flat to get rid of the groove where the brushes run. The brass conductor tab is quite thick and you can remove a lot of material without damaging it.
Post A Followup
: Re: Re: Continuing missing F-20 engine saga
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
