SM blowing oil out #2 exhaust manifold
Posted by Jonesy on December 08, 2003 at 17:04:22 from (64.136.26.225):
Have a SM that makes according to the gauge 75# oil P when running. It blows oil out around the manifold gasket on #2 exhaust port. The tractor didnt smoke @ all until we ran it for some time. Now it smokes intermitently. Pulled off manifold and found oil all in the #2 exhaust valve. Im 99% sure that the rings in the cylinder are good but havent done a wet/dry comp check yet. I degreased the area and held the starter in for a while and built up around 40 #'s oil P. Oil was leaking down the valve stem from the head. Im leaning towards a bad valve guide but I could use a second opinion . Ive never seen a guide leak that much oil past if thats the case.
Post A Followup
: Re: SM blowing oil out #2 exhaust manifold
