Re: Hooking up 3 point Hydraulics on M
Posted by john d on December 08, 2003 at 18:31:31 from (64.12.97.12):
In Reply to: Hooking up 3 point Hydraulics on M posted by Farmall Don on December 08, 2003 at 09:07:37:
As stated in an earlier post, you only need one hose. Put a breather plug in the other end of the cylinder (if it's a 2-way cylinder) and the oil will flow back to the pump through the same hose when the pressure is released.
Either front port will work fine. If you have two cylinders on the 3pt, use them both. The rear port on the left may be used, and will not have any delay unless oil can flow from the front ports. I have a loader on the front ports of my M, and a 3pt on the left rear port. Ball-type shut-off valves let me lock either unit in place when running the other one.
Post A Followup
: Re: Re: Hooking up 3 point Hydraulics on M
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
