Re: Changing H to 12 Volt without cutting hood
Posted by ron on December 08, 2003 at 22:54:50 from (198.81.26.75):
In Reply to: Changing H to 12 Volt without cutting hood posted by David in Texas on December 08, 2003 at 09:12:19:
YOU CAN USE A 12 VOLT GEN. FROM A 1965 FARMALL CUB, IT WILL FIT THE BRACKETS, AND USE THE SAME BELT.THE ONLY MOD YOU NEED TO DO IS WELD A BOLT ONTO THE END OF THE SHAFT SO YOU CAN PUT A NUT ON THE H PULLY,AND YOU HAVE TO GET A REGULATOR FOR 12 VOLT. I DID THIS TO MY SUPER H, AND IT LOOKS JUST LIKE A 6 VOLT TRACTOR.
Post A Followup
: Re: Re: Changing H to 12 Volt without cutting hood
