Re: Farmall H waterpump
Posted by aaron on December 09, 2003 at 11:17:26 from (130.20.144.81):
In Reply to: Farmall H waterpump posted by Outlaw on December 09, 2003 at 10:42:24:
It is going to be work,
First, undo bolt on steering rod in front of the universal joint just ahead of the temp and oil guages. Remove the woodruff key as well.
Second, get a cold chisel and loosen the nut on top-front of the steering bolster and remove steering stick by twisting and pulling from front of tractor.
Third, remove fan shroud bolts and stabilizer rod.
Fourth, unbolt radiator from beneath and pull straight up and out it comes.
Now, you are finally ready to remove waterpump.
Atleast, I think this is the only way, as there is no room to pull the pump out with the shroud in the way?
Maybe a fella could just remove the shroud and slide it over the fan blades allowing room to pull the pump? But I think it is too tight a fit.
Have fun!
-Aaron
Post A Followup
: Re: Re: Farmall H waterpump
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
