Re: Well I better do the TA.
Posted by Dan on December 10, 2003 at 21:15:01 from (12.160.160.160):
In Reply to: Well I better do the TA. posted by Kelly C on December 10, 2003 at 19:13:26:
I got a rebuilt ramp and roller setup from Steel wheel to fix my SMTA. Believe they had a kit with seals and gaskets you need also. I got gaskets from IH along with some seals and others from NAPA. You could get a changeover Sprague type TA setup from Steel Wheel for a bit more than the ramp and roller setup but you had to get a different carrier also. While in there you will want to check ta clutch disc and plate. Not sure what would clunk in there though. Think the rebuilt ramp and roller setup was only about $100, gaskets and seals 60 something. I think the clutch disc also runs about 100 though. If you get in there and there are problems in sun gears or carrier you might be better off with a rebuilt unit.
Post A Followup
: Re: Re: Well I better do the TA.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
