Re: Re: Re: Well I better do the TA.
Posted by Wayne on December 10, 2003 at 22:09:42 from (64.185.17.89):
In Reply to: Re: Re: Well I better do the TA. posted by Kelly C on December 10, 2003 at 20:31:09:
I had something very similar and it was a bearing out on the axle. The inside one next to the ring gear. It will crack the housing if that is what it is, because the big ring gear is going to enentually wear through the bottom.
Post A Followup
: Re: Re: Re: Re: Well I better do the TA.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
