Re: Re: Why you shouldn't buy a stuck tractor...
Posted by jf on December 11, 2003 at 03:04:25 from (67.232.144.14):
In Reply to: Re: Why you shouldn't buy a stuck tractor... posted by Dieselrider on December 10, 2003 at 20:05:45:
Watch what you say or the government will start an entitlement program to ensure equality in tractor restoration.
Post A Followup
: Re: Re: Re: Why you shouldn't buy a stuck tractor...
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
