Re: M overheating
Posted by rustyfarmall on December 11, 2003 at 04:40:13 from (207.32.13.197):
In Reply to: M overheating posted by 1951M on December 11, 2003 at 03:06:08:
The temperature sender is located to the rear of the engine on an M, if the temperature goes up while going downhill, and goes back down while traveling uphill, it has to be because the coolant is running away from the back of the engine when going downhill, and is no longer covering the temp. sender. I think you need to double check the coolant level, It needs to be up to where you can easily stick your finger in it, not just covering the core.
Post A Followup
: Re: Re: M overheating
